Perform the following procedure to view and edit RSMLT local VLAN information.
- In the navigation pane, expand ConfigurationIP.
- Select RSMLT.
- Select the Local tab.
- Configure the parameters as required.
- Select Apply.
Local Field Descriptions
Use the data in the following table to use the Local tab.
Name |
Description |
IfIndex |
IP interface identification. |
VlanId |
Specifies the VLAN ID of the chosen VLAN. |
IpAddr |
Specifies the IP address on the RSMLT VLAN. |
MacAddr |
Specifies the MAC address of the selected VLAN. |
Enable |
Displays the RSMLT operating status as enabled or disabled. |
OperStatus |
Displays the RSMLT operating status as either up or down. The default is down. |
HoldDownTimer |
Defines how long the recovering/restarting system remains in a non-Layer 3 forwarding mode for the peer router MAC address. The range of this value is from 0 to 3600 seconds. The default is 60. |
HoldUpTimer |
Defines how long the RSMLT system maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 1800. |
SmltId |
Specifies the ID range for the SMLT. A valid range is 1 to 512. |
VrfId |
Identifies the VRF. |
VrfName |
Indicates the VRF name. |
